if possible would like to salvage how do you hook up to it to remove,,,I have a wrecker so lifting it wont be a problem ,, what are the options?? the tank is 110 gallons probably original 1989 and its been sitting surrounded by wet foam and i think some of the water is salt,,, I started to remove the foam to help it dry out around the stringers and I know the bottom that the tank is sitting on must be soaked is there a way to remove safely? do I drain the tank take out the sender then use a flat bar on a rope put it in the tank then turn sideways would that work noticed the water and broken up foam on the right side do you think leaving it in is a option /
