Buckeyedude
- Joined
- Apr 4, 2012
- 238
Hey all, I need to pull my 1989 175hp rude to replace the transom on my project boat. I have never done anything like this and would appreciate all and any input or recommendations on this matter. I have been doing some searching and watched some videos, so Im not clueless, but I would rather go into it with as much knowledge as possible. I cant seem to find lifting brackets on it, so I was going to make a steel plate drilled out to the bolt pattern on top of the flywheel, and use that with an eyebolt to lift it off( grade 8 5/16 bolts). I will post some pics here shortly to make it a little more clear on my plan of attack and see if most,some, all or any of you agree with this method!
Also, it really seems unnatural to disconnect everything that is going to or from the motor:dread:
Thanks
Thanks
