removing a 305
jeepofino
Can someone direct me to a post on removing a 305 and the steps to take? I am sure it's already been posted and covered before. Thanks.
jeepofino
Re: removing a 305
#2 April 24th, 2009, 10:43 PM
boatguya1
Re: 1992 Mercruiser 4.3L
--------------------------------------------------------------------------------I found this............sound about right?
Step 1 remove the outdrive
Step 2 remove wires and hoses
Step 3 leave bell hsg attached
Step 4 remove front mount large nuts
Step 5 remove rear mount bolts that hold bell hsg to transom bracket they a
are screwed in facing down on eaither side of the rear of the bell hsg.
There are 2 of them, don't loose the spacers,springs, or fiber washers
that are back there.
Step 6 pull engine
James
Don S
Re: removing a 305
That is NOT how it should be done.
Would help a lot if you posted what engine and drive you have and what year.
jeepofino
Re: removing a 305
It is a 305 mercruiser (GM) 1982 model in a sea arrow ski boat.
