Removing a flywheel from an AQ125...
2stroke1971
Short of having "Volvo special tool number_______ whatever it was in the manual,
How can I remove the flywheel from an AQ125A? Bellhousing is off, I removed the small bolts around the flywheel, looks like some thin plate should come off but it wont....
So at this point, I dont even see the large bolts around the center that Ive got to remove...
Any advice would be appreciated!
Thanks!
PiratePast40
Re: Removing a flywheel from an AQ125...
That thin plate is the flywheel damper and yes, it comes off first. Once it's off, you'll see the flywheel bolts.
