Haywood123
- Joined
- May 10, 2008
- 64
When I bought my boat it came with a Guest model 2401 isolator, which seams to work fine keeping the starting and trolling batteries charge, but I am switching to a 24V trolling system and going with an onboard charger, so I want to remove the isolator. The following picture shows how it is attached to my 1992 Evinrude 150 intruder, with the white wire splicing in and running to the isolator and then the other 2 wires from the isolator going to the positive terminals on the batteries with the negative terminals are grounded together. My question is, will simply removing the white wire and pulling the isolator and disconnecting the tie between the negatives be all I need to do to separate the starting and trolling systems and will the starting battery still continue to be charged from the alternator or was there something else done somewhere else down the wiring that I will have to hook back up?
