mudweiser
- Joined
- Jun 21, 2007
- 115
Noticed a slight fuel odor when the boat was beached last time i was out. Luckily we were beached close enough to the landing to walk the boat back and load it up. Thats not very fun to do in 30MPH winds BTW. Poked around and found that fuel will leak out of the sending unit gasket when the boat is tipped back such as when beached, loading or unloading "basically when the fuel is at the top rear of the tank". Ok, replace the gasket right? Well it's a bit more complicated then that, heres why. One of the sending unit screws has a broken off head. I bet if i remove the others and the sender, there will be enough of the screw sticking up where i can grab it with a vise-grips. I understand the risk of explosion as i have seen sparks fly when a clamped vise-grip slips off a bolt. Thats why i asking for suggestions on how to remove it safely. The boat is a '89 Bayliner 2050 Ariva with a 20 gallon aluminum fuel tank if that helps any. I know i need to replace the sending unit gasket, but i'm not sure what is the safest way to remove the broken bolt. The tank has about 12-15 gallons of fuel left in it now.
