Hi all,
We got some lightly used manifolds as backups and the seller didn't package them very well. The petcock drain part that stays in the manifold itself got whacked and is cracked right up close to the manifold (#8 in the link below). (The thumb screw part itself that you take out for draining wasn't included, no big deal). I didn't realize that the thumb screw wasn't going right into the manifold when we drain each year but it looks like there's a threaded insert with a wrench point on it.
OMC, Johnson & Evinrude - EXHAUST & COOLING - 1987 OMC Stern Drive 4.3
We were going to try some spray lube and gently turning it hoping the whole thing doesn't come off and leave the piece screwed into the manifold but I suspect there's some kind of lock tite on the threads from the factory and wanted to consult the experts here first.
thanks for any thoughts!
