Removing Carbon ?
RMcCann
How do you remove carbon from a 150hp. 1992 Force ourboard...Is their a fuel additive ?
eurolarva
Re: Removing Carbon ?
Hello RMcCann and welcome to iboats. This topic is covered under the forum of Frequently asked Questions. If you click on the link I have provided you will find everything you want or need to know. Good Luck<br /> Link for DECARB
jayhay74
What is the advantage of decarbing will it boost performance?
LubeDude
Originally posted by jayhay74:<br /> What is the advantage of decarbing will it boost performance?
The advantage is longer engine life and better all around performance. You need to get the carbon out from under the rings mostly. Carbon under there can eventually cause seizure and cylinder scoring.<br />---------------------------<br />
