Re: Removing Carpet Adhesive w/out damaging glass/resin
Rjarrau,<br /><br />I actually ended up buying some 'goof-off' and it seemed to loosen the adhesive a little bit. I then hit it with a wire brush (handheld), and it got a lot of it off.<br /><br />From there, I started sanding it with 40grit (have to sand anyways to apply the durabak coating). I'm about 1/4 done with it, not too bad.<br /><br />I still need to find a way to get the engine bolts off so that I can coat the durabak underneath them. I dont have access to a engine hoist, so this may be interesting. I may have to rent one...<br /><br />I am trying to get this thing sanded, coated with durabak, and reinstall everything by Friday (this weekend!!). I am ordering the new rubrail from bluewave tomorrow.<br /><br />here's a quick pic of what the 1/4 that I've done looks like, waiting on durabak (and haven't cleaned it, just swept it off).<br /><br />
<br /><br />Does that look sanded enough for a coat of durabak? It is 40grit. I basically just sanded the excess glue off, and a little bit of resin (not too much). There are low spots where there is still some glue, and still some gelcoat, but the majority is sanded. I think this stuff should stick fine with it like this as long as I clean it well.<br /><br />Mine, nothing like fiberglass sanding!! I'm itching like crazy!<br /><br />Take care!<br />Shawn
