removing cleats on a 1991 2502 TROPHY
Gwadadede
I have to replace 2 corroded cleats on a 1991 2502 TROPHY, but I do not know if they are attached with nuts inside the hull, and if I have to cut the hull to reach them, or if they are only attached with external screws.
Is anyone familliar with these problems? :confused:
Monterey10
Re: removing cleats on a 1991 2502 TROPHY
I've replaced cleats and railings. In each case, the cleat or stanchion base was thru bolted. In each case, I could get to the bolts under the gunnel by removing cabinets, refrigerators or seats. This was not as hard as you might think. I posted some pictures of my railing rebuild here:
http://www.baylinerownersclub.org/gallery/album658
Hope this helps
