removing decals
jvb
anybody know any good tricks for removing old stickers from fiberglass? i need to peel the old reg. numbers off and they are really on there...
JustMrWill
Re: removing decals
Heat gun and old credit card (I use the fake ones discover sends with the "offers" - make sure not to over heat and damage fiberglass<br /><br />GooBGone - works well but still takes alot of elbow grease.<br /><br />Buffing wheel with buffing/rubbing compound - makes quick work of decal...just be careful not to put too much pressure or you burn/damage fiberglass.<br /><br />or any combination of above.<br /><br />-JustMrWill
Stratocaster
Re: removing decals
There are two ways to do it that work really well.<br /><br />1. Use a hair dryer to gently heat the decals, and carefully work the edges with a plastic scraper. Don't hold the dryer in one place too long...keep it moving, because gelcoat melts very easily.<br /><br />2. Buy the 3M electric drill attachment that is made for exactly this purpose. That's what the pros use. It has a bunch of tiny hard rubber balls on SS wires and rips the stickers off without leaving a mark on the gelcoat.
karrick
Re: removing decals
If there is any residue, WD40 will help loosen it to be easily wiped off. <br />Good Luck
Nos4r2
Re: removing decals
soft plastic scraper and then repeated cleaning with a pad soaked in lighter fluid works well.
umblecumbuz
Re: removing decals
Hair dryer, then thinners on a rag to remove any stickiness, then polish to stop the thinners discolouring the gelcoat.
Ralph 123
Re: removing decals
WD40 is the ductape of liquids. It takes adhesive off great. Also works wonders as a cleaner especially for oil and grease. It's even (an illegal) fish attractant! The stuff is amazing!
jvb
Re: removing decals
i used the hairdrier trick. i think the stickers were 20 yrs old! a little heat and the peeled off with a plastic scraper. i used goo gone to remove the adhesive. took a while, but it worked great!
Holdimhook
Re: removing decals
WD40 is the ductape of liquids. It takes adhesive off great. Also works wonders as a cleaner especially for oil and grease. It's even (an illegal) fish attractant! The stuff is amazing!<br /><br /><br />Ralph, I'm going to start a thread on that very subject. (Mods, please move it if I put it in the wrong place).
MWBROWN
Re: removing decals
I just took of my old numbers with no problem by peeling them off with my finger nails. They had only been on 2 years. <br /><br />A great item for cleaning the surface before the putting on the news ones, is the Mr. Clean Magic Erasers. Got the hull clean without chemicals.
fireship1
Re: removing decals
The old heat and peel works everytime. Even on twenty year old decals.
