What is the best way to remove a dent in the bottom of my aluminum hull. The dent doesn't appear to be creased, but is more of a depression. It is probably about the size of a basketball. My main concern is that the dent is on the bottom, right at the stern. Where the stern meets the bottom, it is normally a squared angle, but where the dent is, it has actually bent the bottom of the stern in a little. This is right where the aerator pump mounts through the hull, so the flange on the aerator pump does not have a flat surface to mount on.
I was thinking about just taking a rubber mallet and trying to pound it out???? But wanted to check with you folks to see if there is a better way.
