Removing drive shaft/prop shaft
bm258
I think my last topic was a little confusing. I have a 1989 Johnson GT 100. I am trying to remove the drive shaft and prop shaft so that i can inspect the gears. i have already removed the lower unit. Does anyone have any suggestions for this operation?
Hooty
Re: Removing drive shaft/prop shaft
To remove the prop and drive shaft you have to remove the bearing carrier, pinion gear nut and pinion gear. Got a manual?<br /><br />c/6<br />Hooty
bm258
No i don't have a manual. I wish i did. I bought this boat @ 9 months ago. I have had to do a lot of work to it. Can this be done with out a manual? I have gotten the bearings out, but i kinda got stuck after that.
bm258
No i don't have a manual. I wish i did. I bought this boat @ 9 months ago from a dealership and it did not even have an owners manual, much less a repair manual. I have had to do a lot of work to it in the last 9 months. Can this be done with out a manual? I have gotten the bearings out, but i kinda got stuck after that.
bm258
where is the pinion gear nut, and pinion gear?
