w317chester
- Joined
- Jul 7, 2010
- 54
I have a 2003 Regal Session V-drive wakeboard boat that I am removing the engine from so that I can have it remanufactured. The engine is a 6.2 Mercuiser MX MPI.
I would much appreciate any advice from someone that has done this work before and could advise me on the best way to remove the engine. The way I see it is I have 5 options, see below (Also, I have pictures attached showing these locations to give a visual):
1. Remove entire engine and v-drive in one assembly from boat by unbolting all engine and trans mounts and uncoupling the v-drive from the prop shaft
2. Unbolt the engine from the bellhousing, leaving the trans/v-drive (not sure is these two are one in the same or not...please correct me here)
3. Unbolt the engine and bellhousing from the trans/v-drive
4. Unbolt the trans/v-drive in shown location 4
5. Unbolt the trans/v-drive in shown location 5
Any help is much appreciated!
