If the flappers are broken and you're doing this to repair/replace them, maybe check your maintenance log to see when you last checked the internal condition of the risers and manifolds.
Should be checked every 2 or 3 seasons with new gaskets installed.
My boat's previous owner replaced the flappers because they rusted out and broke apart. Manifolds and risers were caked with scale and buildup and rust, and were starting to leak at the manifold <-> riser gasket. If he'd just pulled the risers, he would have known.
