Re: removing flywheel on 85 hp force
Spray with Kano Kroil or Deep Creep and heat with heat gun. Do this and let soak for 48hrs. Set up puller, they type with three bolts and a center screw.
Put bolts well into flywheel so you don't strip threads. Tighten up center screw good an tight. With a three pound mason's hammer or something similar, give the center screw a good rap. Try taking up some more slack and rap again. Sometimes it comes off with one wack, sometimes it doesn't.
Get back to us if it doesn't.
John
