Removing Flywheel
mini-x fan
This is probably a really stupid question, but when I go to remove the flywheel, it turns. How do I hold it still to get the nut and everything off?
Tight Lines
Haffiman
Re: Removing Flywheel
Which engine?
There are different way, but Google:
flywheel holder tool
And check images.
bonzoscott
Stuff soft rope in a cylinder (piston down) and turn the crank nut until it seizes up to break the nut free - reverse for torquing it back down (40lbs).
boobie
A good strap wrench also works great. OMC used them for years.
boobie
Only thing to remember is, if you use the rope trick, make sure the intake and exhaut ports are closed before stuffing the rope in.
