removing foam
jorja rayne
I think I got this figured out for the most part but removing the trim on the out side .can I reuse it or do I got to order new .
Woodonglass
Re: removing foam
Heat it with a Hair dryer or Heat gun to soften it a bit and make it more pliable and then remove it. It IS reusable. Be careful with the aluminum frame and it will all go back just like it came off. You may have to drill some offset NEW holes but that's not a problem. The rubber insert and the rail is all expensive to replace but usually can be found and purchased unless it's really old.
jorja rayne
Re: removing foam
thank u
