removing forward/reverse lever
reybec
i need to replace the plastic cover on the shift lever of a 2003 johnson 50 hp remote control box as the lug where the power trim is screwed to has broken.
i have taken out the screw with the allen key head.
i have even taken the box apart but i cannot figure out how to seperate this lever from the control box.
thanks to anyone that can help
tashasdaddy
Re: removing forward/reverse lever
it should come right off.
reybec
that's what i thought .
i have tried levering it off with a screwdriver,tapping it out with a hammer even hitting it with a hammer but it just wont budge.
5150abf
Just a thought but check for a snap ring, alot of times they get lost in the crud and you miss them.
As I said just a though but I have run into that on other things.
reybec
i'll post a picture tomorrow.
it's 11pm and thunderstorming here at the moment
tashasdaddy
i can understand. it is 8 am here, sunny and cool.
rcracerx
I just toook my OMC remote assy apart yesterday using the Seloc manual.
The instructions for mine were to loosen the allen head screw 3 turns but leave it in. Then take a soft hammer and a punch and tap (pound) on the top of the allen head screw until the handle came out of the shaft. I had to spray a bunch of wd40 and let it sit but it finally came loose from the shaft. Then I removed the allen head screw all the way and it slid right out.
Try that
Rc
F_R
Try that
Rc
Not sure about the 2003, but on about a bajillion other years, that is the procedure. The handle is on a tapered shaft (like a flywheel except it is also splined in addition to the taper)
reybec
Try that
Rc
thank you
that was the answer i needed:)
