Removing Johnson 115 from transom
Rmoore45
I have a 1978 Johnson 115 and I need to pull it off the transom so I can work on the boat. What is the best way of doing this? On the motor there is a metal bracket sticking up with a hole in it which appears to be the lift point but I would like to be sure.
Thanks, Ranger
mark1961
Ensign
Re: Removing Johnson 115 from transom
Yep, the bracket aft of the flywheel is the lift point......an engine hoist is the best device to use......if the motor is confined in a splashwell the steering cable usually needs to be removed as the motor is lifted.
