removing johnson 25hp starter bracket to take off carb.
tom w rhodes
I have a 1999 25 hp electric start Johnson that I need to remove the starter and bracket inorder to remove the carb. for cleaning. Is there a way to get the starter out of the way without having to dismantle the top half of engine inorder to remove starter bracket? I have removed all of the bolts and nuts that I can see holding the starter bracket and starter on only to have it all still solid. Thanks for any help.:confused:
tom w rhodes
Re: removing johnson 25hp starter bracket to take off carb.
Thanks alot for the parts break down on the starter bracket. Once I found the bolt on the bottom from the parts list and disconected the spark advance the starter and bracket came off, and then I could get to the carb bolt. I would never have found the bottom bolt without the parts list.
F_R
This thread is six years old, so the moderators probably will move your question. After they do, I will post a picture.
