Re: Removing Lower Cowl On 1955 Mark 6
Hi Bill,<br /> The lower units USUALLY crack around the trailing edge of the gearcase bullet. USUALLY they crack fairly cleanly right where the rear spanner nut lies. If yours has, then it is sometimes possible to clean off that cracked portion and reuse the housing as is. However, this involves a modification where you thin the rear carrier to allow the rear spanner nut to bite in new threads. How much you thin it depends on how much of the rear threads remain. If memory serves you should have about 1/4" to play with. It's not always possible, but it can be done on many of these. Make sure you leave enough of an air gap in there so that the water will have a place to go. That gap is in line with the intake holes in the housing and needs to be there so the motor will pump water.. If you do go this route, it's a good idea to tear the whole unit down and replace all the seals while you're at it. <br /><br />Looks like you're in for pulling the powerhead. Not really difficult, though. Be careful not to kink the neutral clutch cable, otherwise it becomes a real pain in the behind to feed back down. Pull it out and tape it up in a neat small coil.<br /><br />Having fun yet?<br /><br />- Scott
