Removing lower unit 1975 6 HP Johnson? Shift rod question.
w2much
Garage sale find for 40.00 makes me a happy camper. Starts up and runs fine. Not pumping water. I will check the tstat first . I see in the parts diagram the shift rod is two pieces. I remember on my very old 40 and 35 HP's there was a plate which when removed revealed the clamp which connected the two halves of the shift rod.How does this l/u come down and where is there access to the clamp on this motor?
w2much
Re: Removing lower unit 1975 6 HP Johnson? Shift rod question.
The answer to my question and more info was found on Leeroysramblings.com Google it if interested. Great info on many small older OMC engines
Rick.
Be careful. There is a small pin at the upper end of the drive shaft that is necessary. I threw mine away only to realize later where it came from. When re-installing the drive shaft you will likely need to turn your prop a bit until the pin lines up. Best of luck. Rick.
