I want to remove the lower unit. I have removed the 4 - 7/16 bolts that holds the gear case to the mid section. I have also removed the shift connector window and the lower screw... the shift rod is now free but the lower unit will not slide out. It seems like the drive shaft is still connected somehow.
The book I am working from mentions that some year/models require pulling the power head to remove the lower unit.
Could this be one of those?
It looks like someone tried to remove this before as there is a good sized ding in the cavitation plate.
After cleaning up the carb and restoring the tank she started right up and we ran it for about a minute but shut down to check the gear oil and water pump.
Since the gear oil looks like a delicious creaming vanilla milkshake I want to inspect the seals etc.
Please help.
Please help.
