ssmith32256
- Joined
- Sep 12, 2009
- 31
I am planning on pulling the engine out of my boat. It is a 153 CI mercruiser 120 4 cyl. I am aware of the single front mount. My question is what do I need to remove near the rear of the engine to free it. I think I had heard someone say that there are two bolts that need to be removed (one on each side ) near the rear of the engine block. Is this true ? Is that all (except wiring) that I need to remove. I have taken several engines out of cars but this is a first on a boat. I was told that if I do this right its quite easy and if I do it wrong I will create a bunch of additional work for myself. If it matters agter removing the engine I intend to remove the transom plate and gimbal ring. Thanks !
