Removing mr outdrive
bigbob_FTW
Got the lower unit off no problem. The upper is loose but stuck at about an inch gap. Is it safe to pry? Doing a bellows replacement. I don't think the water intrusion was long term.
Ayuh,..... Put a block of wood, at the top, 'tween the drive, 'n transom, the use the trim rams to push it off,.....
