Re: Removing old decals
Ditto on the hair dryer (or heat gun VERY carefully used) to get the decal itself off. For the glue residue, bonafide adhesive remover works for sure. But there are several common products you might have on hand that will also work: mineral spirits, rubbing alcohol, lighter fluid, etc. Most adhesive removers are made from those things or a combination. Only warning is use a little in an unobtrusive place to make sure it doesn't harm the underlying finish. Also, you might see a "ghost" after you remove the decal - the exposed finish might be a little duller, or shinier, or maybe less faded, than the old. Most of this stuff can be rectified with a little polish. Good luck.
