Re: Removing Paint From Gel Coat??
Have you tried paint stripper? Interlux sells some intended for boats. Do a search for "paint stripper" and I think you will find some brands that folks have had success with. <br /><br />One thing to keep in mind is that the gelcoat usually needs to be ruffed up a bit before paint is applied. Also the gelcoat exposed to the sun may look a little different than the gelcoat under the paint once the paint is removed.
