hkeiner
- Joined
- Oct 17, 2006
- 1,055
Is there a trick or special way to take the plastic limiter caps off the low speed jets? I don't want to damage the caps by forcing them off the wrong way. I tried to pull them off by hand and they did not budge. I tried pulling them off gently with a pair of pliers and they did not budge. I tried prying them off gently with a screwdriver and they did not budge. I did not want to use too much force for fear of damaging the caps or bending the jets.
I understand that these caps are intended to prevent the jets from being screwed out past their operating range during normal operation. My intent is to screw the jets out completely to take a look at them for apparent wear or gumming. I understand that after I remove the caps but before I remove the jets, I should first screw the jets in to a full gentle stop and count the number of turns, so that I can set them to the same position afterwards. I also wanted to check that that all six caps are positioned on the jets similarly and that the six jets are screwed out a similar number of turns (or fractions of turns).
Thanks for any suggestions or cautions on this simple task.
