removing power head on 15 hp
big joe
81 evinrude mod# e15rcis was over heating I think the rubber grommet is bad have removed all the bolts and power head is still tight no way to pry it loose any way to break it loose with out breaking something else please help big joe
Joe Reeves
Re: removing power head on 15 hp
If you've removed all six bolts, there's not a lot you can do other than to pry up wherever possible, and/or to hit the flywheel sideways with a mallet. Some of those things (9.9 & 15)seem to be glued on!
big joe
Joe Reeves thank you for your input I will go out and try that I put a cable around the flywheel an lifed it up with the engine weight hoping to break it loose will go back an try hitting it side to side thanks big joe
P.V.
Here goes. 1st, remove the lower unit (disconnect the shift conector ) 2nd, remove the tiller arm throttle shaft. 3rd, remove the smaller, corrosponding throttle shaft located in the streering bracket. 4th, remove the six powerhead bolts. 5th, take a good size screwdriver and put it between the lower motor pan and the steering bracket and pry up. The powerhead and pan, as an assembly, will come right off. Remove the powerhead straight up and place it on it's flywheel. The water tube (some have two) will be pointing up into the air. Remove the 4 bolts and the tuner and water tube come off and viola, there's the tube and grommett. Blow clear the water passage on the block. <br />Putting the powerhead is not too donting but you must be carefull for the water tubes. Don't bugger them up. Put a rubber band around the watertube and the tuner. Stand at the port side of the motor and you will see just between the block and pan so as to get the water tube in it's proper place. It can help to have a friend down below with a long screwdriver and guiding the tube down. If you have two water tubes( long and short, realize that the short one goes into the aft cavity. You can see where by looking from below. See, it's e.z. Good luck !!!
P.V.
I re-read my post. You do not have to remove the carb, shift linkage at the top, mounts or anything other than what I stated earlier. As you pull the powerhead up and away from the exhust hsg, the pan, powerhead, water tubes AND the shift rod will come along for the ride. Hope this helps.
P.V.
BTW, this is exactly the way you change the upper mounts. OMC flat rate used to be 3.8 hours. Not to brag... OK, I'm bragging.I've done it in one. If there's not too much salt. But I've done more than one, too !! Anyway, this is by far the best, fastest and eziest way to do it. Hope it helps you.
