Removing Powerhead on 2004 Yammy F150
Shermanator31660
So, the manual says there are a total of 15 bolts that hold the powerhead on. After searching and searching, I've managed to find and remove 7 bolts, four from up front (two on each side) and the 3 that are at the very rear. The manual says there are 4 long skinny bolts on each side of the powerhead that must be removed as well, it would appear these are the ones that are eluding me! Anyone have a diagram or is there something else I have to take off (apron is off) to find these missing 8 bolts?? Thanks...............Sherm
Shermanator31660
Cancel, obviously had a brain fart or something going on, the bolts couldn't have been much bigger! When they said "long skinny bolts" I was looking for something with a #10 metric and not the big bejesus bolts that also hold the oil pan to the leg! Anyways, just have to figure out a different pulley system to get the block off the leg now, thanks...........Sherm
