removing/replacing ac compressor on a 97 4.6l f150
PmDavis300
anyone ever do this? how hard is it, what is involved? if its hard, is it possible to buy a smaller size serpintine belt and bypass the compressor. seems to me the belt would still pass over where the compressor pulley is now.
pinkham89
Re: removing/replacing ac compressor on a 97 4.6l f150
unless you have the a/c recharge machine, youre SOL. Those little refill kits from walmart dont do nearly what they claim. If you dont care about a.c however, you should be able to tear the pump out and either use a shorter serp belt or you can sometimes get a bypass pully that mounts in place of the ac pump
Rickairmedic
Changing compressors isnt a walk in the park but if you are mechanically inclined its not that bad . the important thing to remember is unless you have a vacuum pump you will still have to take it to a pro and get them to vacuum the system and charge it after you swap out the compressor ( quickly after ) .
Rick
sportsmanphil
Something isnt right here.
If your AC isnt working the pulley will still turn. Why do you need to bypass the pulley?
If the bearing/clutch of the compressor is bad, they can be replaced without dumping the freon, but you will need a puller.
So why are you wanting to replace the compressor or bypass the pulley?
PmDavis300
the bearing is bad. how do i get the bearing out without taking apart the compressor?
Rickairmedic
You should be able to rent a puller from Autozone when you purchase the new pulley/bearing.
Rick
