93 140HP with a dead trim motor. So I've managed to remove the top pin on the tilt assembly after banging on it for three days; had to grind off the tilt adjusting rod because that was rusted in place, just so I could remove a couple of transom mounting bolts that were themselves in the way of two of the trim assembly bolts. Successfully removed all the trim assembly bolts and have tilted the assembly forward enough to access the three trim motor mounting screws, which are of course practically welded to the assembly with rust.
Any suggestions on how to remove those screws? I tried a propane torch but I was afraid I'd mess something up internally in the trim assembly with the heat. Is it possible to drill the screws out, or is that asking for trouble?
So far I haven't been able to depress the tilt cylinder enough to completely remove the trim assembly. Will it compress all the way?
