I have to swap my current 1969 Johnson V4 115HP electro shift powerhead into another leg assembly of exactly the same model. I am unsure how to remove the powerhead. <br /><br />The powerhead is currently supported by an engine hoist.<br />Have removed the 2 bolts and 2 double threaded inerts located mext the steering arm assembly.<br />I have removed the 6 bolts which go vertically up into the powerhead (Still does not come loose)<br /><br />QUESTIONS:<br />1. How many other bolts/nuts are there.<br />2. When I remove the powerhead does the bottom bottom part of the casing come off with it.<br /><br />Once I have removed the powerheads I should be ready to go. Is removal of powerhead documented in the standard manual ?<br /><br />Pleeeeassse....<br />Can anyone send me an image of page in the manuel which shows the exploded schematic
<br /><br />Cheers
