Jim Hawkins
- Joined
- Mar 11, 2013
- 506
I want to repaint my old CrownLine runabout.
It currently has a topcoat of questionable material that is flaking off. I have removed most of it by the method that worked best, a flat razor. What's left will take forever using a razor. Paint remover doesn't work very well either. I don't want to just sand and feather the edges because I fear if I leave any it will also flake off at some point. So I want it all off.
If I sand it down to nothing I worry I will take too much of what's underneath.
I'm not sure what it is, paint, epoxy, gelcoat? It is hard and flakes off, doesn't peel.
Any ideas? Suggestions?
*I wanted to add, this is NOT the original topcoat because I can see where fittings were taken off the bow and the holes filled in before recoating.
