I am in the process of trying to remove the<br />trim and tilt from my 1988 90 hp Evinrude. There<br />is a lot of corrosion I would like to remove and also have some leaks. I have removed tilt pin and<br />the 6 bolts. Where do you disconnect the tilt<br />motor wiring. Is the disconnect under the motor<br />cover, or is there one possibly hiding under the<br />wiring sleeve between outboard and motor?
