Removing Water Pump Pulley From 5.0 Mercrusier?
Quarterwave
Hi Everyone,
Just wondering if there are any tips for removing a water pump pulley from an old 5.0 Mercruiser?
I've attached a pic to show you what it looks like. The 4 main bolts have been removed, but it's just not budging - even after I hit it a few times with a brass hammer.
Am I missing something? I couldn't find the exploded diagram for it in the Mercruiser factory service manual.
Thanks!
Bt Doctur
You could remove the pump first for better access to the pully with a brass/dead blow hammer
A product called "Free-All" , any penetrating oil and some heat . Looks like it got wet
rust would not be in the manual
spray some penetrating oil on the shaft where it comes thru the pulley, let sit for a bit
you can also gently pry between the waterpump and pulley. that will break it free.
you will need to buy a new marine waterpump for your swap to the 5.7
Ayuh,.... As noted above, the only thing holdin' it on, in the picture is Rust,...
biggjimm
Some Emery cloth or sand paper may help to clean the shaft up & give it a blast with penetrating oil then it should pop right off. Might need a little pry-suasion.
Quarterwave
Thanks everyone - yes, I have the new marine waterpump ready to go, just trying to get this off so that I can clean it up and install.
I'll have another shot at it this weekend!
biggjimm
Make sure the pulley isn't bent or beat up if you're re-using it.
Any little nicks in it can chew your new belt up in short order. Ask me how I know...... atleast there was no radiator to tear up when the belt broke on the boat. Unlike my truck. Lol.
Good luck.
Jim
Quarterwave
UPDATE - hi everyone, I was able to get this pulley after a lot of Kroil and some banging with a brass hammer.
Thanks for the responses!
