Re: Removing wrist pin
You didn't say what motor, but most OMC/BRP motors have wrist pins that are slip fit in one side of the piston, and press fit in the other side. The w/p boss inside the piston will be marked with a "L" or something similar indicating the loose side. Best way to remove it is an arbor press, with tight side down, pressing from the loose side. In other words, press it all the way through the tight side. To do it opposite will distort the piston. To install, pin goes through the loose side, into the supported tight side.
Yes, heat will help.
