Hi,<br /><br />I am on the way to replace the carpeting in my aluminium fish boat, it is 10 years old. I already removed the front deck and strip the carpet on it, the plywood board is still in good shape but since I am in the processing should I put a coat of any wood preservative or not on the plywood ?<br /><br />Also what you guys use to seal between the deck and the livewell, originally it was some kind of plumber putty, should I use the same stuff or use some kind of silicone sealer instead ?<br /><br />Thanks<br /><br />Smoky
