I have a new to me boat that I just put a new 350 long block in. maiden voyage went well. ran it a bout an hour with no problems. second time out it started leaking oil from the front crank seal behind the balancer. I replaced the new seal with another new seal. went back out for the 3rd time no problems. take it out today for its 4th trip and notice after loading it back on the trailer its leaking oil again from the same place. upon closer inspection I realize the seal is pushed almost all the way back out of the timing cover. after i thought about it i remembered that the first leaking seal was pushed out a little. what could be causing this? it fits tightly, I have to drive it in with a block and hammer. I have never seem this before. should i be putting somekind of adhesive on it? has anyone seen this before? timing cover was straight and square when removed from the old block and did not do this before. seal is a good quality felpro piece.
thanks
jimmy
thanks
jimmy
