NGABaldEagle
- Joined
- May 21, 2006
- 63
Casting deck has a weak section.
When you see the entire casting deck in the pic you can see the hole where the pedestal base was installed.
The weak area is outlines with a black sharpie.
Its real solid and may be solid inside some of the lines as it isnt exact.
However, AT THE LINES IT IS SOLID AS i WEIGHT 265 AND IT DIDNT BUDGE.
I have limited access underneath but I do have some as there is a hatch to access the underside.
My question is what would be the best approach to repair this where I end up with a flat casting deck surface again?
I have thought about adding a 1/2 sheet of marine plywood to cover the whole deck and just starting over.
I just dont know what my options are.
What would a professional do to repair this?
Thanks for your help.
See pics
See pics
