Repair kit/breakdown equipment etc
LadyFish
boateric wrote to me suggesting that I post up a list of items you would carry in a tool box on your boat in our Safety section. I think its a great idea but I need your help compiling a list.
..." tools, electrical wire, variety of wire ends, testers, nuts, bolts, alt./ power steering belts etc. " were some of the suggestions by boateric, what do you carry ?
dingbat
Re: Repair kit/breakdown equipment etc
If you are diligent about your preventative maintenance, you need to carry very few items.
Fan belts, wire harnesses, water pumps just don?t go out. They wear out long before they fail. A simple inspection will reveal a failing fan belt or a failing water pump impeller long before they actually fail. Wiring problems just don?t pop up overnight either. Corroded connections are easily spotted before they fail if you routinely inspect your electrical system for signs of trouble.
I carry a small waterproof tool kit, a spare fuel filter w/ wrench, a box of miscellaneous fuses, a dozen tie wraps, a spare prop with hardware, a couple of new spark plugs and a 20? lg. piece of 12 ga wire.
LippCJ7
I bring my field tool kit for work, it has a good selection of sockets and wrenches electrical connectors and crimpers, DVM and a few other things, the bag weighs about 40lbs so to list everything would take me awhile. I have spares for my boat on board like a spare serpentine belt and impeller, some rtv silicone, plugs(DUH) but I agree with dingbat PM PM PM(Preventative Maintenance), I don't like to work on my boat when I am out on the water but for some reason I love working on other peoples boats so I am helping broken boats on the water all the time. I just enjoy spending time on the water and helping someone to enjoy their day on the water is rewarding, I pulled 3 sinking boats in to the ramp last year and my wife thinks I am McGyver!!
ezmobee
Vise grips are key cuz you never know what you might need to hold together out there. I think my uncle had a pair on his steering rack for about 5 years. Anyone who boats where there are crab traps around NEEDS a good pair of wire cutters.
ralphl
wire cutters and pliers are a must mono is everywhere and will wind up in the prop have, spare plugs,plug socket ,a bit of wire to hold things together till you get in,and enough tools to tighten things up at the ramp
DaNinja
Spare filter/separator(s) and a filter wrench has been a life saver on a couple of occasions.
A clear, wide mouthed container big enough to contain the contents of the filter. A funnel can be helpful as well.
A spare prop and the tools and hardware to remove/replace it.
A portable power pack can save the day. I have never needed it on the water, but there are many boaters that are glad that I was carrying it.
Home Cookin'
A frequently discussed question but important, especially "in the spring of the year when kings ride off to war." We're talking about stuff in addition to safety equipment.
Like all things boating there isn't an answer; it's all about circumstances and judgment. So I won't give my whole list.
There is the strategy of redundancy and even double redundancy. Literally, you'd have to tow a duplicate boat behind you. But taking a policy to absurd doesn't mean it's bad policy.
The question can only be answered in context. Boaters in remote areas or subject to rough conditions need more, as do boaters with older equipment and equipment regardless of age in salt water. The Saturday-only lake boater doesn't need to be able to fix as much stuff as the week-long cruiser, or the guy who relies on the boat as sole means of transportation off a remote island (me).
My theory is that rather than carry a supply room of replacement parts, carry tools and materials to temporarily fix a problem that must be fixed, and to fix a small problem of convenience (the extra screw for your bimini fitting, for example--no hassle to carry, no problem to fix, even though that "equipment" is not essential.) No reason not to carry small, light-weight tools and materials either just in case: no reason not to have a circuit tester, for example, but not a giant socket set.
Cable ties, hose clamps, duct tape can fix a lot of things, crucial or just for convenience. Cotter pins and needle nose pliers for when you have to pull your prop, clear line, and put back on, because they don't make floating cotter pins. A small hammer and block of wood. Vice grips as suggested, fuses and some electrical wire so you can jump over a bad section, to tie something up.
Think of items with double use: wire for electrical or securing; screwdriver for screwing or prying, etc.
How much stuff you carry is also a function of the room in the boat for it, and where you otherwise do your maintenance work. If you are next to the garage, you might not carry as much. I keep one boat in the water and it's large enough, so I keep a well-supplied tool box in it. Another is an hour and a half away in a remote location. So I'll need to have more than someone else.
If you find it prudent to carry a spare prop, don't forget a prop nut. You can get home without the bushings and washers, but not the nut. Unless you have a floating version.
Anyone who says he doesn't need to carry any spares or tools because his boat is perfectly maintained has been godsmacked. Brand new boats break down. it's like, I don't carry a spare tire b/c I am a careful driver, maintain my tires, and don't run over stuff.
And you can't have too many plugs!
partskenn
Don't forget the duct tape
Captain Caveman
In addition to some of the above, I keep some sand paper to clean corroded connections (it's a boat, there's water, things carrode). I also keep a lighter in my boat bag because it's a great way to temporarily clean a fouled spark plug.
LadyFish
These are great suggestions guys, thank you for your input! :)
seaboo
Spare bow stern light bulbs, fuses, and most importantly a spare set of keys to the boat and truck (I carry a spare boat key in the truck and keep a spare truck key in the boat). I've never needed either one, but I have been on friends boat where they left the boat keys at the house or lost truck keys on the trip (after a ride back to the house, or waiting on their wife to bring spare keys, I vowed I would never let that happen to me).
Home Cookin'
I keep a spare boat key cable-tied under the dash to some wiring. I keep a spare car key cable tied under the car, too.
