Re: Repair manual?
this is the correct manual, that motor is fairly simple to do. remove the 1"x2" plate on the side of the leg, take out the bottom screw, pay attention it has to go back together just like that. remove the bolts on the i think 7 bolt on the foot, the unit should drop right out. 3 or 4 screws on the water pump housing, do not loose the key to the impeller, soapy water on the impeller makes it easier to put back together, o ring goes on top of drive shaft in groove. make sure water tube line up, and bolt back up.
