One of the trimcylinders on my Volvo Penta 290DP-A is leaking and I want to repair it with new seals. According to Volvo Penta it cannot be repaired and I have to buy a new set. Is that correct?<br />The Z-drive is from 1989 and with the round type of cylinders with a round inside nut with 4 pinholes at the end where the pushrod comes out. At the end of the pushrod i mounted a joint for connection tho the driveframe. ie it is not the older type with square ends - that type can be repaired. Hope that someone has experience in solution af this problem.
