I have an 18' Aluminum Deep V Lund boat with a 115hp Outboard Motor. The transom is clad in Aluminum. There is another piece of alumimum that butts up against the transom on the inside of the boat that looks like it was welded together or had some kid of sealer in the past. It looks like there is a fine crack along this butt joint and it is leaking inside the boat. Any suggestions on how to repair this crack? I don't think you can weld aluminum so I am assuming I would need some type of metal sealer. I am not sure if the wood transom got soaked but hoping it did not.
Thanks in advance for your advice.
Joe
Joe
