benscott
- Joined
- Nov 1, 2009
- 14
Ok, so went out to check on my boat today which is wet slipped and found that my hull had been scraping against the wooden divider between my boat and the boat in the slip next to me. I guess my line had developed a bit too much slack (change in temperature maybe?) which meant the wind had been pushing it into the divider. On top of this my fender had busted open. Needless to say, I've got a 4" area that will need to be repaired. Should I be concerned about the damaged area getting wet? The area is approximately a foot above the water line so it's not in danger of getting wet while in the slip but I'll be pulling the boat out of the water soon for the Spring maintenance and will need to motor about a half mile over to the ramp. Think I'll be ok or do I need to apply a temporary fix? Duct tape maybe?
