Repairing omc, check risers? Thru hull
Tommywalton
Im repairing a 1988 chaparral omc 5.7/cobra. The problem was siezed engine from water intrusion through exhaust valves. What is the best way to test or check the risers/manifold for water leaks into exhaust passage? Also are the rubber flappers on thru hull exhaust simply enough to keep water from flooding back into engine? Thanks
Tommywalton
Re: Repairing omc, check risers? Thru hull
Thanks for the link to the parts. I want to check these first if possible to.
