Replace 2bl Carb with a 4bl on 165 6 cylinder
sculbert
Guys has anyone tried replacing the old 2gc carbs with a 4mv? I have a 165 6 cylinder that need the carb replaced. Wondering if I would do better putting a 4bl on it. <br /><br />1978 Merc 165 6 cylinder.
Rickles
Re: Replace 2bl Carb with a 4bl on 165 6 cylinder
Yes it can be done.the plate on the manifold is the same bolt pattern as 4Barrel.You'll have to make a new pivot anchor for the cable and redo the fuel line.We used a stud and went through the valve cover& epoxyed in place to seal it.It added some HP but ran so much better.
sculbert
Did you use the 4mv Carb or did you use a holley 4160?
FreeBeeTony
I also have the IL6. Rickles, you say it ran better? How so? Mine runs great with the 2bbl. How much HP did you gain?
