whitejamie99
- Joined
- May 12, 2005
- 105
Just took the heads off. Starboard side head gasket blown at top. <br /> <br />Is there any other prep that needs to be done to either the head surface or the block before I put it back together? Also should I pull out the deflectors and check them while I have the heads off? Do I need to do anything special with head bolts other than proper torque?<br /> <br />Go Spurs Go<br />Jamie
