Re: Replace Johnson power trim relays with solenoid?
I cant recall if you have a 3 or 2 wire motor.That said,what I have successfully done is.Get a Ford starter solonid.Run your blue ,(up) wire to one of the large legs,bring a #6 maybe 8 wire from positive source to the other large leg,from your switch bring the UP to the small lug on the soloniod that activates the solonoid,bring the downside and attach it directly to the grn (down)motor wire.The reason for the soloind on the up ,is ,it takes a good bit more current for the upside due to weight friction etc,for motor to run without any lack of amperage,You can do the same for the downside ,but as long as your tilt tube that allows your engine to tilt has no heavy resistance,the wire to wire should work fine,Ive done it many times,if your engine is stuck,you might want to go for the 2 solonoids,they arent expensive aftermarket ,find a spot in the cowling to mount them,maybe on the rear exhust plate between the heads ,use one of the existing bolts for exhust cover,I only used one bolt and never had a problem,that will give ground to the soloniod.You probably should put a fuse in the feed line supplying power to the solonoid(s),if you have 3 wire you have a seperate ground to the TNT motor
